Burnt A for parts?
Tom Farris
12-12-2005 13:37:30
The rear axle housings (final drive housings) on my '43 A are busted. A farmhand tried to use the tractor to pull tree stumps and I assume he didnt take out the slack in the chain and the resulting jerk bent the drawbar and the housings busted. I found a parts tractor locally but it has been through a building fire. I wonder if the fire would have caused any damage to the housings other than melting the seals? Would the housings be safe to use? Thanks!
andy r
12-12-2005 20:14:27
 Re: Burnt A for parts? in reply to Tom Farris, 12-12-2005 13:37:30
I have been told that if the casting still has oil in it after the fire it and the internal gears/parts are more than likely OK. Now what it would do to axles is another story especially considering safety. Just what I have heard. Good luck.
Lewis
12-12-2005 17:08:57
Hi Tom,
I have been using a Farmall 100 for the last 5 years that was burned badly enough to burn both back tires and one front tire completely off. Other than an axle seal that leaks slightly,there were no long term effects. I repainted the tractor; actually I have a picture posted on the tractor photos, just look under Farmall 100. I don't think you will have any problem, especially if you are going to put new seals, bearings, etc. in the housings.
Bill Geer
12-12-2005 15:55:36
Hi tom I would be interested in the block from that burnt a. the casting number I need is 6342DH.
Thanks Bill
Bob
12-12-2005 13:45:15
The cast iron housing should be OK. Gears and bearings might have lost their "temper", though.
