Starter butten
dave from MN
12-12-2005 15:12:12
Just trying to avoid wasted trouble shooting here. I went to start the 544 today and when I hit the butten it did not do a thing, finnally kinda "hit" it with my finger and then it worked. Anyone ever have these push buttens go out and was this what happened?? I got a million things going on right now and would like to cut to the problem and just replace the butten if this is what it ussually is? Thank you
K.B.-826
12-12-2005 15:48:21
 Re: Starter butten in reply to dave from MN, 12-12-2005 15:12:12
I"ve seen them go bad before, usually the clutch pedal saftey switch gives the most trouble on the gear drive tractors. I"m not really up on the Hydro tractors, does yours have any saftey switches?
dave from MN
12-12-2005 16:10:18
 Re: Starter butten in reply to K.B.-826, 12-12-2005 15:48:21
yes, ya have to have the foot n inch pedal in just like a clutch. It is positioned properly but I suppose I may have to do a make /break check on the switch next time. I am sure it will work fine now till I get 20' snow and -10. Which will probably be mid January when the flock goes out and the barn needs to be cleaned. Didnt have a single mechanical problem last year, got a feeling its gonna catch up. Preventative maintenance some how always loses to bad luck, my times a coming
old
12-12-2005 15:24:38
Could be the button or it could also be a loose connection some place like the battery or the cables
