Order Farmall Cub Parts Online
R-cubed small alternator
Keith-OR
12-12-2005 20:58:07
Hey I did not make it to shop this evening to get you the wiring diagram for Mitsubishi alternator and pictures, forgot last nite that I had to take my boy ,Shawn, to Special Olympic basketball practice tonight, We just got home about 20 minutes ago..... He has practice every Monday night....will get everything you need tomorrow...SAT
Keith & Shawn
Tractor Tom
12-13-2005 06:26:00
 Re: R-cubed small alternator in reply to Keith-OR, 12-12-2005 20:58:07
Thanks Keith, family first. I think I have got the Mitsibishi alt half figured out. The R terminal goes to the ignition, L terminal normally would go to a alt light? How did you wire yours, and did you use a blocking diode to prevent battery drain?
If R-Cube is reading this, on the original discussion, it looks like the smaller import alternators are a better choice for Cubs with clearance problems but my Cub has the Delco 10SI and I have seen others with it. Maybe the bracket has to be just right or the hood on the later models was more generous?? In answer to his original question, there are several options available with internally regulated alts and you can check out the articles on this site or check the archives for Bob M posts on the subject.
R-cubed
12-13-2005 18:31:48
 Re: R-cubed small alternator in reply to Tractor Tom, 12-13-2005 06:26:00
Yes, I'm watching. Spent the day in the country working on my klunkers. (65 miles from my computer) I have a 1947 Cub and I never tried to put a 10SI on it but it looks way too big. Probably depends on the mounts. May have to modify the mount considerably. I saw a pic of a guy's Farmall with a big slice taken out of the hood to clear an alternator. I can't tolerate that.
