Order Farmall Cub Parts Online
Picture of Cub alt. bracket
Keith-OR
12-13-2005 19:16:19
Here is the picture of alternator bracket and wire hookup. Wire for the light or diode is hooked to "L", red wire "R" (on my alternator)is hooked the the Bat, lug on my alternator. Got wiring hookup from friend that runs a gen,starter alternator rebuild shop. If you need my measurements for bracket email me....HTH
Keith
third party image">Link
third party imageLink loading="auto" style="width:auto;height:auto">
Tractor Tom
12-14-2005 06:26:51
 Re: Picture of Cub alt. bracket in reply to Keith-OR, 12-13-2005 19:16:19
Keith, thanks for the pics, I don't know if you saw my post from Tuesday: "I think I have got the Mitsibishi alt half figured out. The R terminal goes to the ignition, L terminal normally would go to a alt light? How did you wire yours, and did you use a blocking diode to prevent battery drain?" Based on your comments above, I wonder if my alt will self excite?
Keith-OR
12-14-2005 09:18:33
 Re: Picture of Cub alt. bracket in reply to Tractor Tom, 12-14-2005 06:26:51
Yeppers Tom, saw your post on hooking up your alternator, but I figured I would post how mine as wired to conferm what you had posted. Mine wiring came directly from the manuel, we had put it on the test machine to make sure was working properly....Hope you get yours going. As you can see I am still working on my Cub, only thing left is fenders tho..... thanks
Keith & Shawn
Bill Geer
12-13-2005 22:45:51
Keith
What kind of altnater is that ?
Keith-OR
12-13-2005 23:05:51
 Re: Picture of Cub alt. bracket in reply to Bill Geer, 12-13-2005 22:45:51
Mitsubishi....this one only needs the one wire as it will self excite, but I am going to hook up L as I already have it in the wire harness.
Keith & Shawn
Keith-OR
12-13-2005 19:37:59
 Pic alternator mounted in reply to Keith-OR, 12-13-2005 19:16:19
Alternator on engine, so you can see how it fits. Lots of room under hood....
Keith & Shawn
Tractor Tom
12-14-2005 19:00:55
 Re: Pic alternator mounted in reply to Keith-OR, 12-13-2005 19:37:59
Thanks Keith, great pictures, sorry I didn't read your post closer before I responded. You covered everything I needed to know and now the light in my brain finally came on :-)
