Order Farmall Cub Parts Online
Hyd Leak on Cub
Florida Tom
12-14-2005 12:14:56
I have just bought a 1958 Cub that was in storage in 15 years. It runs great, and couldn't be happier, but now all of sudden I have a pretty good hyd leak, and it looks like it's coming from under the resvior. It leaks when I park it over night. Does anyone have any suggestions what I should look for?
Thanks so much.
Bigdog
12-14-2005 13:08:28
 Re: Hyd Leak on Cub in reply to Florida Tom, 12-14-2005 12:14:56
There is a bottom plate and gasket on the touch control unit. You may either have broken bolts or a bad gasket. Worst case - a cracked reservoir. Gaskets and rebuild kits are available from Case IH. Get the number from the side of the unit as there are a couple of them.
Florida Tom
12-14-2005 17:34:11
 Re: Hyd Leak on Cub in reply to Bigdog, 12-14-2005 13:08:28
Is it hard to remove the hyd tank? I saw four bolts on the bottom. And I think it has an arm going from the control handle too.
Bigdog
12-15-2005 13:23:02
 Re: Hyd Leak on Cub in reply to Florida Tom, 12-14-2005 17:34:11
not hard at all.
