B parts on a SA
bjk
12-14-2005 16:48:19
I'm just starting to restore a 1948 super A. I will be needing some major parts, especially need a grill and left final drive assembly. I found a B that I can get for a song and I'm wondering of a lot of the parts aren't interchangable. Can anyone tell me?
bjk
bjk
12-15-2005 07:12:05
 Re: B parts on a SA in reply to bjk, 12-14-2005 16:48:19
Thanks for the informative responses. I do need the Final drive housing - mine is cracked - and I'd rather not have to modify the grill. The B is actually in pretty good condition externally but the engine is stuck, manifold and starter are missing. I may go ahead and pick it up anyway. I think I can get if for $200 and it's only about 30 miles from where I live. May be able to get my investment back on ebay.
bjk
gene bender
12-15-2005 03:14:17
Grille can be cut to fit around steering sector. Final drive parts will interchange but not the housings as the drawbars mount with different stuff. Depending on which parts you need mite not be too good of a deal unless you could sell the B stuff when you are done.
BILL BOWEN
12-14-2005 18:35:23
the grill is diffrent on the bottom, cutout for the steering box on the A THE A/B FINAL DRIVE HOUSINGS ARE ALSO DIFFERNT. THE SUPER A IMPLEMENT MOUNTINGS ARE DIFFRENT TOO. YOU CAN USE THE GEARS THATS ALL .
kopeck
12-14-2005 17:51:13
I think the grill is taller on an SA then is a A/B/BN.
There's some other changes too (engine, and torq tube come to mind).
BIG JOHN
12-14-2005 17:12:26
Sure they will fit. The only difference between an "A" and a "B" is the width of the rear axel and the wide front end viris the narrow front end. The SA will have hydraulics and the "B" won't. This will mean that the "B" engine will not accept a hydraulic pump.
GOOD LUCK
old
12-14-2005 17:06:33
Not sure about the SA but I know a lot of parts from the A and B swap. And my catalog doesn't even show a SA so my guess would be yes they swap. But thats only a guess.
