H Starter short circuit
Rock2k
12-14-2005 17:23:06
I have a problem with the 6V starter on our H. It was working OK, but suddenly it seems to have gotten a short somewhere. I think the gear got jammed on the ring gear the last time it worked, but now all I get is a pop when I try to use it.
I took it apart, and although I'm no expert, it seems that the issue is either worn brushes (they look pretty worn, but SEEM to be making contact), or the 'arm' that connects from the starter's post to the windings.
So 1) would worn brushes cause a popping/short circuit? 2) What should the resistance be between the post and the starter housing when assembled? (I'm getting around 4 ohms, which seems wrong, but I'm not sure). 3) How do the windings connect to the post? What I have looks like a total hack. The 2 'arms' from the windings seem to just lie in the slot of the post. That can't be the way it's supposed to be. I think the one arm may be touching the commutator, because it's pretty bent up and looks a little 'scorched'. I tried to bend it back to where it goes around the housing nicely, but it's a little short to reach the post when I do that, and it still seems to have the short.
Any initial ideas? Anyone have any pictures of a disassembed, good starter?
captaink
12-14-2005 19:25:33
 Re: H Starter short circuit in reply to Rock2k, 12-14-2005 17:23:06
With the starter completely disassembled there should be infinite resistance (no conductivity) between the post the battery cable hooks up to and the starter field housing. Also as you touch all the bars around the commutator (the copper bars on the armature that the brushes ride on) there should be conductivity between them but not to the steel part of the armature or armature shaft.
Sometimes if the bushings are worn enough the armature can drag on the field housings and cause enough heat to melt the insulation and cause an internal short in the windings. If you have a growler (older device for testing internal shorts in armatures) test it (or take it to a place that has one like an automotive machine shop) to make sure it isn’t internally shorted. Check the brush connections. Two of the brushes should have a braided wire to the housing end cap, and the other two should be connected to the field windings (taken out from the access holes behind the narrow band on teh commutator end of the starter) which connect to the post on the field housing that the battery cable connects to.
While the starter is completely disassembled if you have current flow from any copper part (including brushes) to a steel part (except brush holders), this is where the short is at. Once the starter is assembled, then there will be conductivity, since that is how electric motors work.
If you don’t find a short after the above tests, I would recommend replacing the bushings and the brushes get a good brush arm and put it back together and bench test it. You won’t have much in it.
Good luck. e-mail me if you have questions.
Rock2k
12-14-2005 20:29:20
 Re: H Starter short circuit in reply to captaink, 12-14-2005 19:25:33
With it disassembled, I believe everything is as you describe it. I was assuming there would be more resistance when it was assembled, but maybe not.
But when it's assembled, I'm still worried about how the winding's arm is routed, and how it connects to the post. It seems like that's the only suspicious part now, and could explain why it seems fine when disassembled, but it shorts out when assembled. How much room is there between the arm and the housing, and between the arm and the commutator (steel part)? I think it must be touching one of those two right now, and I can't seem to get it right.
And how does the arm connect to the post? I just don't see how there was ever a solid connection there, although I don't think that's my immediate problem.
Thanks
captaink
12-15-2005 06:30:07
 Re: H Starter short circuit in reply to Rock2k, 12-14-2005 20:29:20
I’m not exactly sure what you need, so I will probably give you more than you are looking for.
This is from memory, but I believe that two brush arms share a pivot pin and mounting bracket on the cover of the starter. Behind each arm is a spring that holds the brush firmly against the commutator. There isn’t a lot of clearance between the brush arm and the commutator or the field housing of the starter, since the movement required for the brush arm is relatively minimal. The brush arm should not touch anything except the brush, the pivot pin and the spring that holds the brush against the commutator (armature). If the brush arm touches the commutator, a new brush may be all that is needed to correct this. The brushes normally extend about 3/16 of an inch between the arm and commutator.
The connection of the “grounding” brush is straight forward, braided wire to the end cap of the starter. The “hot” one may or may not be so straight forward. When you disassembled the starter, you should have had to remove two screws from wire leads or possibly a flat copper piece in order to get the end cap off. This is where the “hot” brushes connect. This may be a direct connection to the terminal on the starter or may be a “tap” off the field windings; I’m not positive on yours as starters can be made either way.
The power flow is from the terminal on the outside of the starter where the battery cable connects, through the field windings on the outside of the housing to two of the brushes (hot) through the commutator to the windings in the armature, out through the two grounded brushes. That being said, the connection of the “hot” brushes is actually made to the field windings or directly to the terminal on the starter. I have seen starters that have had an oversized flat screwdriver slot in the bottom of the terminal that the battery cable connects to and the field and brush leads were soldered into this grove. Possibly on yours, it may have gotten hot enough to melt this solder out and that is why you are not seeing where the connection is at.
Hope this helps, fire back if you have more questions…
Rock2k
12-15-2005 09:49:38
 Re: H Starter short circuit in reply to captaink, 12-15-2005 06:30:07
Excellent! Good stuff.
I explained part of it wrong (I knew I would). The 'arm' I was talking about is the thick metal 'lead' from the windings to the external post. The longer one is all scorched, and I was thinking it was either making contact with the housing, or with the end of the commutator. Unfortunately you can't really tell when it's apart, and there's no way to get to it when it's assembled.
It looks like the solder from the 'lead' is long gone if it was on there (it's the large screwdriver type post). I'm surprised this isn't more of an issue, as it seems like the routing of the lead is pretty error prone, and it doesn't seem as those there is alot of room for error/movement.
I'll check the brush arms though also, as that's a good idea. Maybe they were touching the copper.
Thanks
captaink
12-15-2005 10:10:14
 Re: H Starter short circuit in reply to Rock2k, 12-15-2005 09:49:38
To fix that connection I find it is easiest to do a good job if you take out the field block mounting screws from the outside of the case and take out the field coils and the terminal post. This will allow you to use a “heat sink” to protect the insulation on the coils, and get both the field coil lead and the post clean and hot enough to get the solder to hold good.
Glad I could be of help. Good luck with your starter.
