Puller built 4 SC
Keith-OR
12-14-2005 21:02:52
Bob theBillder, finished my puller just need to set it up for porta power. How you coming on yours. Think I will remove polster off Shawn's SC tomorrow and remove pully. Plate is 3/4x8x8,with 3 inch hole, rod 3/4 all threat 24 inchs long(haven't had a chance to cut it to the length I need yet).The square tube I used 2x2x9" with 0.250 wall thickness....
Keith & Shawn
third party image
Chris in Washington
12-15-2005 12:43:39
 Re: Puller built 4 SC in reply to Keith-OR, 12-14-2005 21:02:52
Keith, that is truly a work of art. I have been following this thread with interest because I have the same task coming up with not only my SC but my cub. The front seal on my cub leaks like a sieve and I need to pull the pulley on the SC so I can replace a cam gear. Wish me luck.
the tractor vet
12-15-2005 08:11:16
Mine has Snap On and OTC on it , but your cost alot less then mine did.
Keith-OR
12-15-2005 09:58:23
 Re: Puller built 4 SC in reply to the tractor vet, 12-15-2005 08:11:16
Tractor vet, not only cheaper, it has the satisfaction of going from some old scrape iron to a finished product. The only thing I had to buy was, one piece of all thread $6.00.
Just like taking an old tractor that looks like it is ready for the scrap pile and bring it back to life....:-) :-)
Keith & Shawn
Dixieland
12-15-2005 06:37:27
Hey Keith! Whatcha gona pull with it? Probably a dumb question but..... jus wonderin.
Rex
Keith-OR
12-15-2005 07:02:37
 Re: Puller built 4 SC in reply to Dixieland, 12-15-2005 06:37:27
front crank pully off the boy's SC. Need to put in new front seal.....
Keith & Shawn
Dixieland
12-15-2005 07:32:07
 Re: Puller built 4 SC in reply to Keith-OR, 12-15-2005 07:02:37
Looks like you could pull a train with it! I used a bearing seperator and 3 point pulley on mine. It was kinda tough though!
Rex
Keith-OR
12-15-2005 09:47:57
 Re: Puller built 4 SC in reply to Dixieland, 12-15-2005 07:32:07
Horror stories, I heard so many of them when it comes to removing that front pulley, even breaking the pulley. So I decided to make a puller that I did not have to use a torch and no chance of breaking the pulley. The plate is almost like the one in repair manual, except I will be using porta power(hydraulic) instead of a large puller...
Keith & Shawn
Dick Davis
12-15-2005 02:45:22
Shucks, I thought I was going to see a new SC with cut rice tires, wheelie bars, and lots weights on front! LOL Dick Davis
Keith-OR
12-15-2005 06:25:38
 Re: Puller built 4 SC in reply to Dick Davis, 12-15-2005 02:45:22
Foooled you. huh Dick....:-) :-) :-)
And I never thought about someone thinking that....
HA HA HA HA....
Keith
Karl Hamson
12-15-2005 10:35:46
 Re: Puller built 4 SC in reply to Keith-OR, 12-15-2005 06:25:38
Hi Keith
I have been trying to send you an e-mail through this site and it does not seem to be getting through. If you could e-mail me at hamson@gulfislands.com then I will have your address and can send you pics of the wide front I have available.
Keith-OR
12-15-2005 12:26:52
 Re: Puller built 4 SC in reply to Karl Hamson, 12-15-2005 10:35:46
Karl, sent you an email, you have the choice of 2 different email addresses....Thanks
Keith & Shawn
