C113 Farmall Engine
Dixieland
12-15-2005 13:43:58
I am having some trouble getting a C113 engine to run smooth. It has to run quiet a while to warm up but untill then about every 3 or 4 minutes it will have a skip. After it warms up, it runs smooth as silk. Another thing is, the magneto trip seems too loud. Makes it sound like a lifter or pushrod is ticking. Is there any way to lower tht noise a little?
Thanks,
Rex
Dave BN
12-15-2005 15:21:38
 Re: C113 Farmall Engine in reply to Dixieland, 12-15-2005 13:43:58
Rex, sounds like you may have an air leak counter acting the choke. Check the tube from the air cleaner to the carburetor, the screws that hold the carburetor bowel to the body of the carburetor, the bolts that hold the carburetor to the manifold and the bolts/nuts that hold the manifold to the engine. Also could be a bad gasket at any of these points and or a cracked carburetor or manifold. The magnito is supposed to "clank" at slow speeds, like during start up. That is the impulse mechanism which gives a hot spark even if the magnito is turning at a slow speed. I can actually idle my BN down slow enough to hear it while running. Dave
Dixieland
12-15-2005 17:00:17
 Re: C113 Farmall Engine in reply to Dave BN, 12-15-2005 15:21:38
Thanks Dave. I have checked for all those possibilities and everything checked good. Looks like I need to go over them again.
Rex
