M idle, carb prob??
Chris Willy
12-15-2005 16:16:22
I recently got an old M running that had been sitting for probably 15 years. At the time the governor was bad and would just race the motor, so I found a different one and put that on. I also had to take the carb apart because it was all full of crap after sitting that long, I put a kit in it and it for some reason doesn"t want to idle nice and smooth. If I idle it down to far it"ll die, and when it is just sitting running the RPM"s will surge up and down. Also when i am driving the tractor it acts like the governor might be not quite adjusted right, it"ll pull down and then after a few seconds it"ll race forward like it shoudl do right away once you let out the clutch. Any help would be appreciated. Sorry bout the long post. Thanks guys
Haas
12-16-2005 07:08:10
 Re: M idle, carb prob?? in reply to Chris Willy, 12-15-2005 16:16:22
I guess you are aware that on the M carburetor to make the idle mixture richer, you turn the idle screw clockwise, or in. To lean it out, you turn the screw out.
captaink
12-15-2005 16:22:22
Sounds like there may be several things going on. First, I think the idle passage in the carburetor is plugged with something which is preventing the idle fuel circuit in the carburetor from providing the correct mixture. Look here first, then if you get it to idle, but the engine speed still won’t remain constant the governor may need new springs, weights, and/or pins to work correctly.
Chris Willy
12-15-2005 16:56:43
 Re: M idle, carb prob?? in reply to captaink, 12-15-2005 16:22:22
Could you tell me exaclty where that port is at? I"m not sure if i know exactly what passage you are talking about. Thanks.
riverbend
12-16-2005 04:54:08
 Re: M idle, carb prob?? in reply to Chris Willy, 12-15-2005 16:56:43
The idle circuit passage runs from the slot by the throttle plate, down to the idle fuel jet, along a cut-out in the cover gasket, down the well refill bleed, to the point where the idle air screw comes out behind the venturi.
The IH or IT service manuals both show this. The IH manual has a better discription of how the various circuits work in the carb. Both manuals are readily available.
riverbend
12-16-2005 05:05:28
 correction in reply to riverbend, 12-16-2005 04:54:08
I was looking at the drawing for an H carb. The M is similar, but has a drilled passage between the idle fuel jet and the main air bleed / idle air needle.
Chris Willy
12-16-2005 06:36:15
 Re: correction in reply to riverbend, 12-16-2005 05:05:28
Thanks riverbend, I"ll have to check that out.
Chris
