Farmall H 4th gear
Guyzoo
12-17-2005 18:32:24
Hi, My H don't stay in 4th gear all others are OK exept the 5th that will disengage once in a while. What could be the problem? How to fix it?
THANKS FOR ALL REPLY
Haas
12-18-2005 18:25:20
 Re: Farmall H 4th gear in reply to Guyzoo, 12-17-2005 18:32:24
If it's only the shifter, you will be very lucky!! More likely some worn out bearings and/or gears. Fixing those requires removing top from the transmission, removing the hydraulic lift all unit and disconnecting the main drive shaft and that is just the start.
Eric Allen
12-17-2005 23:33:29
Probably the shifter is worn down inside so it isn't pushing all the way into gear. Either try a new shifter or build the end of the one you have up a little with weld until it is back to normal thickness again.
