got a hand clutch for my M!
Nebraska Kirk
12-17-2005 20:21:44
I finally found one! Now to install it. Is there anything special that I should know, or do? I was thinking about how to go about installing it, and determined that should remove the PTO unit, remove the bolt holding the bull gear to the axle, slide the axle out of the bull gear, pull the gear away from the bull pinion enough so that the the entire left bull pinion assembly can be removed. I was wondering, will I be able to move the bull gear enough through the PTO hole, or will I need to remove the transmission cover?
Nebraska Cowman
12-18-2005 04:17:22
 Re: got a hand clutch for my M! in reply to Nebraska Kirk, 12-17-2005 20:21:44
Go to Kelly's site
H has some pictures of a disasembled M&W clutch. I think he used to have the book posted but he changed servers and it's gone. email kelly, I'll bet he'll help you out.
Dick Davis
12-18-2005 02:21:00
Kirk, Go to Galleries (left margin), Vintage Ads, search for M&W Hand Clutch and you will find a several page manual that a very nice fellow posted there. I refer to it frequently. My nickel Dick Davis
