M---MD FUEL CAP..ARE THEY THE SAME????
RONEEE
12-17-2005 23:47:15
ARE M AND MD FUEL CAPS THE SAME, IF NOT WHAT IS DIFFERANT? THANKS ALL....
Paul in Mich
12-18-2005 06:30:37
 Re: M---MD FUEL CAP..ARE THEY THE SAME???? in reply to RONEEE, 12-17-2005 23:47:15
Roneee, They should be the same. If you are replacing it, however, it is best you use the tall vented cap, even though it may have been equipped originally with the short cap.
Allan in NE
12-18-2005 06:38:27
 Re: M---MD FUEL CAP..ARE THEY THE SAME???? in reply to Paul in Mich, 12-18-2005 06:30:37
Mornin' Paul,
I was under the impression that all the single tanked IH tractors are the same, aren't they?
Allan
Paul in Mich
12-18-2005 16:11:38
 Re: M---MD FUEL CAP..ARE THEY THE SAME???? in reply to Allan in NE, 12-18-2005 06:38:27
Allan, Within the series, I don"t think there are any differences from one tank to another. An "H" gas tank is the same whether it is gasolene or Distillate or kerosene. An "M" fkuel tank is the same whether it is gasolene or diesel or the others. I know I"m stirring up a can of worms as the "A" and super "A" is different because of the placement of the sediment bowl, but that is another issue separate from the original one being which fuel cap is appropriate. If I"m wrong, I"ll accept the severe lashing with the wet noodle.
Bryce
12-18-2005 23:30:36
 Re: M---MD FUEL CAP..ARE THEY THE SAME???? in reply to Paul in Mich, 12-18-2005 16:11:38
The fuel CAPS are the same BUT the MD tank has a small sump in the bottom that the regular M does not have.There is a difference in tanks.
