400D pump
mulcher
12-18-2005 12:01:25
Bought hyd pump on farm auction that came off of a 400 diesel. Hopeing to put it on one of my W9's or my WD6. After getting it home I see it has no threaded holes for hydraulic lines, just a flat spot with two holes with O rings. Am I missing a part that is available or that can be made or will this even work on any of my tractors? Farmer did have a 400D so this pump is probably the old wore out pump that he took off. Pd $55 for pump so not out to much if it won't work or fit. Tractor had new paint, started and ran and had a good loader. Brought $3100.
Brian
CO
Redrider
12-18-2005 19:02:20
 Re: 400D pump in reply to mulcher, 12-18-2005 12:01:25
Mulcher, remember now that the pump for the diesel is different than the one for gas. The rotate in opposite directions.
mulcher
12-18-2005 19:48:41
 Re: 400D pump in reply to Redrider, 12-18-2005 19:02:20
Checked the rotation of the distributor on the W9 and the WD6 and believe they turned the same way. That was last summer. When it warms up a little I'll check that out again.
Brian
CO
trulyred
12-18-2005 15:10:55
There's a block from a Super "M" that will bolt to the pump that has two pipe thread holes in it. Need a new pump for about half that dealer price? My e-mail is open.
Mcred
12-18-2005 14:35:19
Hey Brian I would seriously try to make it work because we just ordered a new hyd pump for our 450 Diesel yesterday after noon from CASEIH and paid $1150 for it but needed it to run the haybine.
Andy Martin
12-19-2005 06:10:17
 Re: 400D pump in reply to Mcred, 12-18-2005 14:35:19
What are you using a Haybine for this time of year?
