cab insulation on 1466
Yellott Canby
12-18-2005 18:56:55
Hello,
I was wanting to get you alls opinion on cab insulation on a 1466 cab. I have a '72 1466 with an IH cab. It is the kind with the doors that are beveled, not flat like most of them were. Anyway all the insulation is gone from inside the cab. Was wondering if replacing it with new would make much difference on the noise level, would it be worth the money. Thanks for your thoughts. YC
JMS/MN
12-19-2005 08:13:15
 Re: cab insulation on 1466 in reply to Yellott Canby, 12-18-2005 18:56:55
Fehr Cab Interiors, Fairbury, Ill. 815-692-3355. Insulation thickness used to be a major selling point, cheaper cabs had 1/2 3/4 inch, warmer, quiter ones had 1 in foam.
the tractor vet
12-18-2005 19:46:59
A new cab kit will help a bunch along with a new floor mat and get the head liner .
David A. Hodson
12-18-2005 19:12:09
couldn't hurt, it would be warmer too and there's aftermarkit kits out there too. David
Don L C
12-19-2005 15:27:24
 Re: cab insulation on 1466 in reply to David A. Hodson, 12-18-2005 19:12:09
Try Home Depot..... they have all thickness foam, that can be followed with foil pockets of air(i think)tape with foil tape.....leave that way or cover that with wood paneling or 1/4" wood floor under covwring, that looks real good stained and finished.....cost should be less than $200..... Try cheep thick rug on floor....
