Electronic Ig
Dellbertt
12-19-2005 15:12:11
Is electronic ignition just for 12v or is stock 300U (6v)OK? Is electronic a direct change (bolt for bolt) for the points or is there other changes to do.
Hayfarmer
12-19-2005 21:18:58
 Re: Electronic Ig in reply to Dellbertt, 12-19-2005 15:12:11
I have seen them listed for 6 volt also. Believe they are listed in parts section here, there are also other suppliers.
Rich Griffin
12-19-2005 15:17:54
I just installed one on a 350 row crop. Had to be 12v neg ground. Takes no longer to install that than it does a set of points. My parts man recommended installing a hot coil which I did. Boy,does it start now!!!!!1
FarmerSid
12-20-2005 04:31:47
 Re: Electronic Ig in reply to Rich Griffin, 12-19-2005 15:17:54
Hey Rich. What brand name of electronic ignition did you just put on? Would you mind posting the part numbers and supplier you got it from? Want to put the same on my 350 powered H. Thanks!
Cheers!
Sid
