140 Hi-Clear Rear Rim Bolts
Mark Peters
12-19-2005 16:43:58
Does anyone know if the square headed rear rim bolts are plain old grade 2 bolts or are they grade 5`s? Thanks,Mark
Haas
12-19-2005 18:42:16
 Re: 140 Hi-Clear Rear Rim Bolts in reply to Mark Peters, 12-19-2005 16:43:58
I don't know what they are, but I would not put grade 2 bolts in there without knowing. I suspect they are a grade 5 or 8 bolt. I've bought a few of these wheel bolts from IH dealer and surely they would not charge like that for a grade 2 bolt. The square head bolts are readily available in grade 2 (as you are probably aware) from several sources. The higher grades in square head are not so easy to find and when you find them, they are expensive.
Dave BN
12-19-2005 17:26:21
I put grade 8's on my BN. About $100 for 8 bolts and nuts at my IH dealer. They had to order them. I figured they're only 4 on each side so they must be strong. Dave.
