Production Numbers on a 460 Utility?
Buzzman72
12-20-2005 12:58:54
I'm just curious how common--or rare--a 460 utility might be. Looking for something to help Mom out on her 13-acre horse farm, and a Cub just isn't big enough. Thought about a 240U, but they're pretty scarce around here as well...and besides, I like the IHC sixes (have a '51 and a '52 IH L-110 pickup).
Any thoughts on what to look out for? Particular bad points of a 460U? Good points?
Thanks for any and all help.
CNKS
12-21-2005 06:14:45
 Re: Production Numbers on a 460 Utility? in reply to Buzzman72, 12-20-2005 12:58:54
Hydraulics and trans fluid (both use the transmission housing as a reservoir) are usually neglected, meaning water -- drain it out and replace, preferably more than once, replace the filter. If it has had a loader on it the front end is likely severly worn. The torque amplifier may or may not work. Pto may have bad clutches or need adjustment (I have not messed with mine). You need power steering, don't know if it was standard or not, most likely had it. Otherwise, the typical problems any 40+ year old tractor is likely to have. Most 460U's were the usual utility tractor but there were also Hi-Utility, wheatland, and grove models. About 11400 produced, including all models.
