48' MD battery ?
brsii
12-20-2005 18:11:56
hey my MD is 12 volt and is supposerd to have two batteries. do you know if i need two 6 volt batteries to equal 12, or two twelvesa that alternate or something? thanks for the help
Brad In WI
12-21-2005 10:41:23
 Re: 48' MD battery ? in reply to brsii, 12-20-2005 18:11:56
My MD also has one 12 volt battery. If it turns over hard have the starter rebuilt. Mine would barely turn over on gas before I had starter rebuilt. Now it turns over very easily on gas AND diesel. That is also using the same battery, cables, and ignition switch.
Brad
Roger46
12-20-2005 18:57:52
I only have a single 12 volt battery on my MD. As long as you get a reasonable size battery you will be OK. Besides, you start up in the gas mode where the compression is no different than a regular M. Mine even cranks over the engine fine in the diesel mode. Roger
