Venturi
John London, Tx
12-21-2005 17:12:19
I brought a 44H home last weekend and got it running after replacing fuel bowl, carb and magneto. Took the carb apart and found the bottom half of the venturi installed in the carb, but the top half was broken off and the tractor has apparently been operated for some time with half the venturi gone. If any of You Guys have a spare one I would like to buy it. Thanks
RustyFarmall
12-22-2005 05:14:53
 Re: Venturi in reply to John London, Tx, 12-21-2005 17:12:19
Mark's tractors is advertising brand new H venturis for $25. I have never done business with him so can't vouch for him. Phone number is
217-694-4735
Brian Schmidt
12-22-2005 07:57:38
 Re: Venturi in reply to RustyFarmall, 12-22-2005 05:14:53
Ahhh Yes!! I knew I saw one somewhere and was looking in all the catalogs I had to try and help. Mark"s Tractors is a good place to buy from. He will treat you right. I think there was some connection at one time with Mark's and OEM. They are on or nearly on the same level.
Allan in NE
12-21-2005 17:58:51
Yep,
I put mine in upsidedown one time. Wouldn't hardly run.
Flipped 'er over and all was well.
Hope ya find your part,
Allan
lee
12-21-2005 17:39:29
amazing these old tractors will to continue running against all odds.
