560 pistons
redhen
12-21-2005 19:45:25
I have a 58 560 gas I'am overhauling and the pistons I took out are M&W pistons that are 3 11/16 and they should be 3 9/16 did the last owner bore out the block or do I have a diesel block on the tractor?I looked for a casting number on the block but I can't find one.and if so will I have to put a diesel overhaul kit in it?
ejr-IA.
12-21-2005 21:30:45
 Re: 560 pistons in reply to redhen, 12-21-2005 19:45:25
Right now your cid is 282 like that was used in the diesel engines but the diesel was a flat piston with a small cumbustion cup so thats not a option because of low compression for the gas engine.M&W must of had a overbore kit that you had to bore the block for the sleeves and bigger pistons.The 291 had sleeves with a 3 3/4 bore.You need to measure your block to see if these would work.Next option is go sleeveless and use 301 pistons in std which is 3 13/16 40 and 60 over.This is what the 806 gas had and some combines.
the tractor vet
12-21-2005 20:36:13
Well you could get the 263 to 291 over bore and bore the block out and make it a 291 and still have a sleeved block that is rebuildable
MN Scott
12-21-2005 20:08:03
The engine displacment should be stamped on a pad on the block beside the oil filter base.
redhen
12-22-2005 09:09:06
 Re: 560 pistons in reply to MN Scott, 12-21-2005 20:08:03
thanks guys for the info,I found the casting number it's 371237 r-1. I don't know what I'am going to do yet I'am still going to look around and see if I can find a piston that will work
