Can I use Hi-Tac to seal my carb ?
John in Ct
12-22-2005 18:26:46
Can I use a little Hi-Tac to seal a leak in my carb or will the gas cause a problem to it?
Janicholson
12-22-2005 18:38:12
 Re: Can I use Hi-Tac to seal my carb ? in reply to John in Ct, 12-22-2005 18:26:46
Fuels now contain alcohol which can disolve some sealants (I think Hi-Tac) is affected over time. Depending on the leak, putty/paste type fuel tank sealer may do better. Much depends on the type of leak. Cracks are best stopped by drilling a tiny hole at the propegating (narrowest end) to stop it from continuing, then sealing it
