Farmall M 12V Conversion Bracket
Nathan in Ohio
12-23-2005 04:52:52
Does amyone have a link to a site with drawings/plans to fabricate the bracket to mount a GM alternator to a M??
little john
12-23-2005 08:03:49
 Re: Farmall M 12V Conversion Bracket in reply to Nathan in Ohio, 12-23-2005 04:52:52
I put a photo of an alternator in the "Parts and Pieces" gallery over on the left of the page. This was put on the discussion board a couple of years ago, perhaps by the same person who showed you the other picture down below. Thanks to that person, anyhow.
captaink
12-23-2005 06:57:22
When I build mine I flip the original upside down. I drill out the holes the generator bolted to 3/8”. I then shim out the alternator on the front of the bracket with washers or a spacer, your choice. I also build a spacer for between the arms of the bracket. I run a long 3/8" bolt through both arms, spacers, and the bottom of the alternator. Then, I elongate the hole in the top support so that there is an adjustment to tighten the belt.
The advantage to this is the alternator sits tight against the valve cover not modifications to the hood are necessary. Also, the stock belt on the M generator will work if you use the original diameter pulley on the alternator. Actually, unless you are driving a bunch of lights or other high amp load, the narrow pulley from the car will work just fine. Mines been on for about 20 years now…
wh
12-23-2005 05:07:04
here is a link to how i did mine on a H. have 3 like this and been there for SEVERAL years with no problem. the idler pulley makes it easy to adjust the belt. there are 3-4 more pics in the album -- just click view album -- it is the bottom album in the list.
Harley
12-23-2005 09:17:08
 Re: Farmall M 12V Conversion Bracket in reply to wh, 12-23-2005 05:07:04
I have mounted probably twenty or thirty in the past two years just like captaink said, and on the two I use daily, and no problems. Turn the original bracket upside down, a piece of 3/8 althread, and wala. Harley
