H valve guide
lmj
12-23-2005 17:58:36
I don't have the lit. on a farmall. Do you press the guide in from the bottom or down from the top?
El Toro
12-23-2005 18:22:50
 Re: H valve guide in reply to lmj, 12-23-2005 17:58:36
The guide is pressed into the head from the top with champered end up and is 31/32 above the valve spring seating surface. The guides do not require any reaming. Hal
lmj
12-23-2005 19:12:53
 Re: H valve guide in reply to El Toro, 12-23-2005 18:22:50
You don't happen to know the table angle, so the guide is vertical.
El Toro
12-24-2005 03:56:46
 Re: H valve guide in reply to lmj, 12-23-2005 19:12:53
I would take the head to the local auto machine shop and have them pressed in. Hal
