illistrated parts
banjo
12-23-2005 21:19:06
Where can i find proper names for parts on a super A? just bought another tractor(1948) and some peices are missing. just would like to know what they are called when i start searching.Thanks. also it is a mag but it has been bypassed with a coil. need to trouble shoot it and see if it works(mag)it is running with coil. where is the numbers on the carb? all i can see is zenith at the moment. has been run on propane for long time.
will have to pull gas tank and give it a good cleaning and replace sediment bowl.needs some TLC but i think it will clean up good.
El Toro
12-24-2005 06:14:35
 Re: illistrated parts in reply to banjo, 12-23-2005 21:19:06
Clean and adjust those points to .013". Hal
Bob
12-24-2005 05:56:36
The links below are to manuals on the Cub Collector's site:
Magneto:
Link
Tractor:
http://www.cleancomputes.com/Cub/Super%20A%20-%20Super%20AV/index.html
Nebraska Cowman
12-24-2005 03:34:18
you will want to get a parts book for the "proper" names. Do some checking (ebay is a good place) reprints are widely available. Just pull a plug wire loose and see if you have spark. I've seen lots of those conversions and they work fine.
banjo
12-23-2005 22:15:54
closer examination i could be wrong on the mag it has a dist. but where the coil is supposed to be is a square mounted box with one plug for coil wire. on side of dist is small bolt for points voltage. never seen a setup like this. are these type coils still available?
banjo
12-24-2005 07:29:45
 Re: illistrated parts in reply to banjo, 12-23-2005 22:15:54
is there a picture of a mag i could see. the reason i ask is this tractor runs good. buti would like to get it to as original as i could. without extra parts hanging here and there. the guy said it was converted to 12 volt, but the gen is still on it and i dont see any thing that would indicate it is 12 volt. no resistor anywhere.add on coil doesnt tell what voltage it is. there are no lights on the tractor, ignition switch will not stop , have to pull batt cable or ground out.
gene bender
12-24-2005 05:03:32
From what you describe you have a mag.
