Radiator Studs for M farmall
Hfarmall
12-25-2005 19:05:42
Hi, Where is a good place to find Radiator studs. The local Case/Ih does not have them. I've tried the hardware store. Thanks.
sjh
12-26-2005 13:48:42
 Re: Radiator Studs for M farmall in reply to Hfarmall, 12-25-2005 19:05:42
Threaded rod will work, but not original. Then again who crawls under them to look anyway.
Haas
12-26-2005 06:18:48
When I needed one, I went to the local NAPA autoparts store. He went to his bolt cabinet and pulled out one that would work. Did not have the hole for the cotter pin or a fine thread castle nut, but those are not really needed anyway. If you want to put a cotter pin in for security of the nut, just drill a hole for it.
El Toro
12-25-2005 20:40:30
You should check with an auto parts store such as NAPA for your studs. If you have a store that handles only bolts they should have studs too. Hal
Bill Geer
12-25-2005 20:31:14
Try OMC tractor parts 18002832122
Alvin Dick
12-25-2005 19:33:15
Try a parts store.
