Farmall M hydraulic plumbing
Dan Crocker
12-26-2005 03:34:00
I hope everyone had a Merry Christmas!
I have a 1948 Farmall M with a liftall belly pump (orignal plumbing setup, no christmas tree valve. I have a front end loader with one way cylinders, and recently added a three point hitch with two way cylinders.
Can I use a two spool hydraulic valve to control both one way and two way cylinders? Or do I need a single spool valve plumbed to the one way cylinders and a seperate single spool valve plumbed to the two way cylinders?
I assume if I plumb the three point hitch as one way, I could use a two spool valve to control the FOL and the 3 pt hitch. Is that correct?
Dan
Nebraska Cowman
12-26-2005 03:49:27
 Re: Farmall M hydraulic plumbing in reply to Dan Crocker, 12-26-2005 03:34:00
you can use a 2 spool valve. Both valves work independantly. If you hook them up for one way you only need one pressure hose for each valve. The oil will go out and come back in the same hose.
