International 4100
msb
12-26-2005 16:35:02
May be a bit premature in asking since haven't seen it yet,but a friend has asked me to take a look at his 4100.Says it has a small fuel leak on the pump.It won't run at idle,only 1500 rpm and above.Have to prime it each time before it will start,so it sounds like the leak is causing it to lose prime.Now I have rebuilt so many Roosa Master,I can literally do it in the dark,but I have never touched an old IHC fuel system.Any help would be greatly appreciated.Thanks,bob
ejr-IA.
12-27-2005 15:53:27
 Re: International 4100 in reply to msb, 12-26-2005 16:35:02
The early 4100 used roosa pumps should'nt be a problem for you.
El Toro
12-27-2005 06:35:08
Having that leak is probably like venting the fuel line and letting it drain back into the tank.
This will cause air to be in the fuel lines and makes the engine harder to start.
That pump may need a rebuild and the injectors checked. Hal
