986 running problem
Eldo case
12-27-2005 04:54:14
986 will start cold then run a little bit then die and won't start until it has a little starting fluid. The owner said it seemed better with the block heater warm. It will run ok unless you lug it and it dies or you idle it down fast it will die. Then it won't start unless you use starting fluid or it sets for ten minutes or so. Is it the pump? Thanks!
Allan in NE
12-27-2005 07:05:42
 Re: 986 running problem in reply to Eldo case, 12-27-2005 04:54:14
Eldo,
Yes Sir, that is exactly how they act when the pump goes south.
Probably will stay running at high speed and a lighter load or no load to speak of?
Allan
the tractor vet
12-27-2005 06:36:39
I would have to go with a pump problem if your getting good fuel flow to and from the filters .
