M Axle question
Lenn
12-27-2005 08:55:05
I have a M with a grader attachment that has had the axles changed.
Ser. no. FBK- 164259K
It has six spline axles with 32 inch rims and 14-32 tires.
The wheels are held on by a bolt and washer that goes in the end of axle, shown out in the picture.
The center splines wear out on these centers and tires seem hard to find.
My questions are,
What axles and centers are these out of and can i swap out the axles with M axles without changing the axle housings.
I`m thinking about converting it back to M axles and wheels then adding fluid for weight.
Thanks.
[IMG]http://img.photobucket.com/albums/v629/InTheWind/grader.jpg[/IMG]
[IMG]http://img.photobucket.com/albums/v629/InTheWind/wheel.jpg[/IMG]
randy hall
12-27-2005 12:13:04
 Re: M Axle question in reply to Lenn, 12-27-2005 08:55:05
lenn your grader has w-6 type axles and housings. i could help you out with the other parts that you are looking for. i am located in ohio.
Lenn
12-27-2005 12:41:33
 Re: M Axle question in reply to randy hall, 12-27-2005 12:13:04
Thanks for the replies, i`m not going to be working on it till summer i was just wondering if just the axles can be changed or if the housings have to be changed also to convert it back to M.
And maybe i can locate some w6 centers and axles for it around here in MN.
Lenn
12-27-2005 09:00:15
third party image
pic re-try
Lenn
12-27-2005 09:01:41
 wheel pic in reply to Lenn, 12-27-2005 09:00:15
third party image
wheel pic
RustyFarmall
12-27-2005 10:15:22
 Re: wheel pic in reply to Lenn, 12-27-2005 09:01:41
That wheel and axle assembly looks very similar to what is on my I-4, with the exception the I-4 uses 24 inch rims, and yours uses 32 inch rims, so possibly what you have is a match for the I-6 or maybe even I-9 tractors. I don't know about the interchange to Farmall M housings.
