SC head
stu in njo
12-27-2005 09:26:52
I have done the head two times for water now I have a oil problem with #1&2 cyl & coming out ex pipe. I'm thinking bad or broken rings.Any thing more it mite be? Thanks Stu
El Toro
12-27-2005 11:06:20
 Re: SC head in reply to stu in njo, 12-27-2005 09:26:52
Have you ran a compression check? High intake
manifold vacuum may be pulling oil past your valves. The guides may be worn. I had an engine with broken rings. It never smoked and no oil from the exhaust. It did have a lot of blowby and it sounded as if the compression was blowing into crankcase.
When I pulled the head I saw what was causing this. The ring or rings had broken and had cut a groove into the cylinder wall. The compression
was blowing down that groove. A big notch in the piston too. This engine never missed, I did hear
a little noise from the engine. I pulled the engine and had it rebored oversize. Ran like a new one after that. Cost about $600.00 for parts & machining. Hal
