Losing Hydraulic fluid in Super C
George Wallace
12-27-2005 15:19:33
I am losing hydraulic fluid in my super C. Unit is not leaking nor is there any fluid on the ground. Seems like I have too much oil in the crankcase though! I guess my question is, is there any way for hydraulic fluid to transfer into the oil? Sure seems like this is what is hapening.
George Wallace
12-28-2005 19:00:18
 Re: Losing Hydraulic fluid in Super C in reply to George Wallace, 12-27-2005 15:19:33
Thanks everyone. I just happened to have a gasket kit for the hydraulic unit and replaced the o-ring on the shaft. O-ring was broken and brittle. I have not had time to run it yet, but I think the problem might just be fixed.
El Toro
12-27-2005 18:10:32
I should've put that other reply up here on speedi-sleeves. Hal
Paul Shuler
12-27-2005 15:57:16
George, you hit the nail on the head. This is a common thing with the touch control equiped tractors. There is I think two rubber O rings in the pump just in front of the distributer and it is common for these to leak dumping oil into the crank case. Not a hard fix at all. Sometimes there will be a groove in the shaft that requires a speedy sleeve to fix but someone else will have to help you with that. I have not done that. Oh the O rings can be picked up at a CIH dealer if one is close to you.
Paul
Reddog
12-27-2005 15:56:04
Yes the hydralic oil is leaking into the oil pan. You will need to take off the hydralic pump, the fluid is leaking past the pump shaft into the oil pan. Your pump most likely has a seal or a O ring that seals around the shaft that must be bad. If the shaft has a groove worn into it you will need to put a speedy sleeve on the shaft. Hope this helps, Reddog
leon
12-27-2005 17:35:00
 Re: Losing Hydraulic fluid in Super C in reply to Reddog, 12-27-2005 15:56:04
Tell me more about a "speedy sleeve."
El Toro
12-27-2005 18:07:59
 Re: Losing Hydraulic fluid in Super C in reply to leon, 12-27-2005 17:35:00
The speedi-sleeves are available from your auto parts store that sells Chicago-Rawhide seals.
You can call this toll free number for C/R if you have a problem 1-800-882-0008. Hal
PS: Your local Case/IH dealer may have these speedi-sleeves.
