Rear wheel seal on 350
350 HU Don
12-27-2005 19:14:17
I have developed a leaky left rear wheel seal on my 350 High Utility. I've never changed one and don't know what I'm facing. How do I do it?
Allan in NE
12-28-2005 04:02:48
 Re: Rear wheel seal on 350 in reply to 350 HU Don, 12-27-2005 19:14:17
Don,
When I was a boy, I grew up movin' and changin' IH wheels as many as 6 times a season on four tractors because we used different configurations of the same tractor on different tasks on the farm.
As such, I've learned quite a few little tricks and shortcuts over the years on how to handle these buggers. Plus I've got some special tools that I use to make quick work out of this nasty job.
However, I gotta agree with John D on this one!
If you aren't used to wrestlin' these rascals, don't do it like I do because they are very, very heavy, they are totally lop-sided weight and if you don't know how to handle them and if you don't know how to make 'em "walk and talk", they will get away from ya and things will go wrong in a big way.
The correct way is to block up that rear end with some bridge planking to make sure the tractor is secure and then use a crane or loader of some sort to remove the wheel/rim/tire. Even then, you've really got to be careful!
Use a wire brush or some such thing to clean the axle, then give it a good bath of engine oil before putting on the new seal. Biggest risk is cutting that new seal on the lip of the axle groove. Don't forget to replace the o-ring in the retainer as well.
I've got to replace my front end pivot bolster, but I'm not even gonna show you guys how I do that. I'd probably have heart attacks poppin' up all over the country! :>)
Allan
350 HU Don
12-28-2005 05:47:27
 Re: Rear wheel seal on 350 in reply to Allan in NE, 12-28-2005 04:02:48
No problem handling the wheel and tire assembly. I've had that off this tractor a couple of times and grew up on H's and 300's and like you, we moved the wheels for different purposes so I've had plenty of experience with wheels. I'm just concerned about whether I can reach the seal from the outside. I sure do appreciate all the good advice you guys give.
Allan in NE
12-28-2005 07:08:56
 Re: Rear wheel seal on 350 in reply to 350 HU Don, 12-28-2005 05:47:27
Yes Sir,
The seal is pressed in "backwards" in that outter cap that is held on with four little 3/8" bolts.
Then there is an o-ring around the inner centering lip of the seal which seals the cap itself.
Before you loosen the cap, see if there is any "shake" in the axle. That will tell you if the bearing is good or not.
Also, a couple of gallons of hytran is gonna pour out so have a catch bucket at the ready. :>)
Allan
350 HU Don
12-28-2005 15:53:52
 Re: Rear wheel seal on 350 in reply to Allan in NE, 12-28-2005 07:08:56
I've checked the axle, no wiggle so I think the bearing is good. I will now pull the wheel and the axle end cap and see what I find. Thanks again for your help. You guys are great!
john d
12-27-2005 20:17:02
Jack up the wheel, block the tractor so it CANNOT fall or roll. Set the brake on the wheel still on the ground. Get some help to handle that wheel when you remove it, or risk getting mashed. I recommend you NOT prop the wheel in the manner that Allan in NE shows over on the "Tractor Talk" board under post titled "Wife says I'm Crazy." The tire may have fluid in it, and with wheel and wheel weights could easily weigh 800 lbs.
You may be able to remove the end cap from the axle housing and replace the seal. If you have to go further and remove the axle housing for any reason, it's very heavy, and you'll likely want some help. If for some reason you decide to pull the axle, you're in for an adventure.
iester
12-27-2005 19:55:43
I think you can still get this part from cih and felt, not for sure though?
