656 remotes failed
Eric NW Iowa
12-30-2005 09:53:04
My trusty 656 and Westendorf WL30 aren't so trusty as of late.
My brother parked the tactor (fully functional) a while ago and left both levers in float. Went to use it last week and loader was gone (both lift and bucket tilt are gone). You can just see the cylinders try (they barley move 1/8")
Here's what I've checked so far:
power steering - normal
2pt - normal
Thinking ice, moved it to a heated shop for a day - nothing
Talked to local Red mech - said to check for pressure relief or check valve next to seat mount (looks like 1 1/8" hex nut) - I took that out and inspected -- assuming fluid enters it from the end or screen side I tried to blow through it and was able to (shouldn't that be set for much higher pressure?)
sorry for incorrect terminology -- any input?
Thanks,
Eric
hr-ny
01-03-2006 17:46:31
 Re: 656 remotes failed in reply to Eric NW Iowa, 12-30-2005 09:53:04
here`s what fixed mine
i pulled the pressure relief valve out,
pulled it apart turned the adjustment screw in aprox. 2 turns re-installed and life is good all my loader functions returned to normal.
hope this helps anybody else with this problem
howie
hr-ny
12-31-2005 16:48:32
i have a 856 with the same problem, would be
interested with what you find.
i`ll post my fix
Rich Griffin
12-30-2005 15:18:06
Get a different releaf valve from another tractor to try before buying one-kind of pricey
