C hydro pump rebuild kits
jostev
12-31-2005 14:16:10
I was just wondering if anybody knew where to order a Hydraulic rebuild kit for a 1949 C from? I haven"t checked with Case/IH but there isn"t a dealer near, so... Thanks for any help
Jostev
jostev
12-31-2005 17:22:42
 Re: C hydro pump rebuild kits in reply to jostev, 12-31-2005 14:16:10
Thanks for the help, I am wanting to rebuild the PUMP only, maybe the gear etc... I will get back to everybody tomorrow, my brother is having surgery tonight, this just happened today...
If you don't mind, I would like the breakdown. If that's not too much trouble.
Thanks for the help, Johnny
Andrew Z
12-31-2005 17:11:26
I rebuilt the pump on my Super C and the kit comes with new rubber gaskets and some enternal parts. It was pretty expensive though. Also check the gear for wear. I had to repalce mine. Andrew
Peabody
12-31-2005 15:33:32
Are you looking to rebuild the pump, or the hydraulic (touch control) unit?
El Toro
12-31-2005 14:31:43
I think Case/IH has some parts for those hydraulic pumps. I have a parts breahdown on the Pesco pumps. Its for the Super A, its probably the same as the C and Super C. I can email you a copy of the parts breakdown. Hal
PS: You need to check that pump shaft for any wear. Chicago/Rawhide has a speedi-sleeve to cover that area.
