Farmall 350 Rear Hydraulic Lines
Ken(IL)
01-01-2006 07:06:17
Guys,
Recently replaced the rear hydraulic lines on the 350. I noticed when I replaced the lines, there were no gaskets. Now that it is back together, it appears there is a leak. I have not had the chance to pull the dash off to take a look yet, but was curious if there should have been a gasket or if I should have used RTV? Any thoughts are appreciated. Thanks
Ken(IL)
01-01-2006 10:39:03
 Re: Farmall 350 Rear Hydraulic Lines in reply to Ken(IL), 01-01-2006 07:06:17
Guys,
Thanks for responding. I am using the original type steel lines. My guess is the O-rings are missing. I will have to check the old ones I took off the tractor to see if they are there and are still in usable condition. Thanks for the responses.
DWV
01-01-2006 09:52:30
If you are using the original steel tubes,orings
go between the valve and tube manifold were the 3 bolts hold it to valve.
El Toro
01-01-2006 07:18:56
What fittings are used on the hose ends? Are they swivel tube nuts connected to male flared fittings? I wouldn't use any RTV. Hal
