What block do I have?
DelMN
01-01-2006 10:47:05
I have a 4 cyl block with a 3" bore. The oil pressure guage pointing out. (Not to the back). It also has a dip stick tube. The casting number is 6797*D1. Is this a combine block? Can I use it in my Super A?
Thanks
JakeF
01-01-2006 13:12:30
 Re: What block do I have? in reply to DelMN, 01-01-2006 10:47:05
If it was from a baler or power unit it will probably have the starter cutout on the RH side of the block and you will have a halfcircle hole in your bellhousing. It'll work but you will have one less bellhousing bolt ond you should make a plug to keep stuff out of the bellhousing. Jake
Keith-OR
01-01-2006 12:01:12
They also used these on hay bailers and stationary pumps. There should be a serial # just below #1 spark plug. On my stationary engine casting # is behind the oil filter... HTH
Keith & Shawn
El Toro
01-01-2006 11:40:49
They used a C-113 engine in their earlier combines. Someone may know what those casting numbers are for. Hal
