Farmall H Plugs/Plug wires
Farmall in PA
01-01-2006 21:02:02
Hi Everyone,
I'd like to get my plugs and plug wires from a local auto-zone or advanced auto parts store. I know that the plugs are the autolite model 386 right??? correct me if i'm wrong..... And what kind of plugs wires should i by threre....preferably ones that are made...anything in particular to ask for? Brand/Model name? It's for a Farmall H with a MAG
Thanks
Eric
robertw
01-02-2006 09:39:55
 Re: Farmall H Plugs/Plug wires in reply to Farmall in PA, 01-01-2006 21:02:02
HA guys i just put wires on my sh that i got from the ih dealer that are stainless steel wires a maganet will not stick to them and there metal color so i'am sure thats what they are was this a bad choice and if it was why I also put champion spark plugs in d 21's were these a bad choice to thanks
Janicholson
01-02-2006 10:24:23
 Re: Farmall H Plugs/Plug wires in reply to robertw, 01-02-2006 09:39:55
They probably are not stainless. There would be little or no reward for a manufacturer to do that. They may be tinned copper. To see if this is the case (if you are interested) Try to solder a piece of it. If it takes solder reddily, it is tinned copper. Plugs that fire the cylinder reliably, and do not overheat causing preignition, are good plugs. I personally shy away from Champion plugs, however Champion makes plugs accepted as the best there are in formula 1 and other race cars cranking 15-18 thousand rpm.
Good luck, JimN
robertw
01-02-2006 12:35:01
 Re: Farmall H Plugs/Plug wires in reply to Janicholson, 01-02-2006 10:24:23
Thanks Jim they are copper went out in the barn and looked at them they say hypalon copper conductor on the wire i done that this spring and didn't remember that was wrote on them the wire does look like steel through i guess thats the first thing to go memory thanks again
El Toro
01-02-2006 03:51:01
I would only buy plug wires made with copper wire
and the Autolite 386 is a good plug number. Hal
Nebraska Cowman
01-02-2006 03:48:43
Use only copper wires
Janicholson
01-02-2006 07:37:17
 Re: Farmall H Plugs/Plug wires in reply to Nebraska Cowman, 01-02-2006 03:48:43
I agree with the other two posts, copper wire.
However!!!!!I like my copper wire wound around and around a fiber core. Magnetic suppression wire. The reason is that they have no radio static emissions, and full copper conductivity. They also have nice silicone covering that remains flexible in the cold, and resists high temperature melting.
A kit that will fit a Vega, might be a close match. take yours along to compare.
JimN
Allan in NE
01-02-2006 09:24:43
 Re: Farmall H Plugs/Plug wires in reply to Janicholson, 01-02-2006 07:37:17
Don't think the Vega wires are gonna work.
The Vega was one of the very first cars to come out with HEI ignition and the fat wires.
Ford Pinto maybe? They stayed with the point systems fer awhile, didn't they?
Allan
Janicholson
01-02-2006 10:47:29
 Re: Farmall H Plugs/Plug wires in reply to Allan in NE, 01-02-2006 09:24:43
You may be correct (I remembered the HEI on those with the same old 7mm dia) (did you see my post on the Steering issue scotc below?
I'm taking a break from holding sheet rock over my head while driving the screws in with the other hand.
JimN
