Which Carb do I have?
JeremyG
01-02-2006 08:06:55
I have a new Zenith carb with the numbers 12098B L63 stamped on it. The guy said it would fit an A or C. I have a 46 A. I got it mounted barely as the manifold holes did not line up just right and it will idle fine. But when you give it full throttle it starts popping and surging. I check the gas line and also the link from the governor. I think it for a Cub instead. Any suggestions? Thanks
