FARMALL H SHIFTING FORKS GEARS
RICH
01-02-2006 11:46:43
Hi:
Well, here we go again. I"ve got 6 times the money invested in my 8N but it finally works thanks to this website. Now I bought a "bargain" early 1940 FARMALL "H". First problem was the PTO shaft not working . We think we have that going our way now by replacing the entire unit up to transmission. Now we find the gears and shifting forks are worn badly (especially 4th & 5th gear and 1st & reverse shifting fork. The forks apparently change at serial # 19378. Our serial # is # 22500. Should be simple????? The part numbers on our shifting forks do not match anything in the shop manual although they come close to the numbers pre # 19378. What"s up with that? And would any forks we find for an H work? And any suggestions as to a reasonable place to obtain them? I"m finding the shop manual for this is either worthless or I"m not bright enough to understand it. I had a lot of good help on my 8N and am hoping the FARMALL guys are better. Thanks. Rich
Larry in CO
01-02-2006 16:43:34
 Re: FARMALL H SHIFTING FORKS GEARS in reply to RICH, 01-02-2006 11:46:43
Hi Rich,
Check with Mike at SteelWheelRanch, phone number 785-548-7435. I'll bet he's got anything you would need. I've called him several times for stuff for my H and he has always come thru. Reasonable prices, too. I'm not affiliated with him, just a satisfied customer. Larry
Haas
01-02-2006 13:44:22
By shop manual, do you mean parts catalog. You need to get an H parts catalog to dope out the part numbers. I don't know if you can get the 4/5th sliding gear from IH or not. I could not for the super H which is different. Had to go with an aftermarket one. Value bilt has the H 4/5th sliding gear in their catalog. You may find that in the parts on this site too. Hard to find a used one that is good, as the 5th gear is a wear point due to starting out in 4 and shifting to 5.
