farmall 53 super M part #s for trans. oil seal
3mdaniels
01-02-2006 13:01:42
would like the seal part #s of the trans. input shaft seal and counter shaft seal so i could go to my near by auto parts store and pick them up. this way my grandpas tractor that he bought new in 1953 and now i'm restoring it.
Bob M
01-02-2006 17:44:39
 Re: farmall 53 super M part #s for trans. oil seal in reply to 3mdaniels, 01-02-2006 13:01:42
I removed the old seals, found IHC part numbers on them then called my local bearing distributor. They crossed the IHC number to the National Seal equivalents. They had replacements in stock, and the price was about 1/2 what CIH was getting for 'em.
Note: The replacement, synthetic elastomer seals are half the width of the original leather seals. Some people like install two of the new style seals in place of the old single seal and packing the space between the seals with grease. My experience however is a single new style seal pushed about 1/2 way into the seal bore - so the sealing lip is bearing on unworn metal on the shaft - works just fine.
3mdaniels
01-02-2006 18:03:25
 Re: farmall 53 super M part #s for trans. oil seal in reply to Bob M, 01-02-2006 17:44:39
the old seals were to rusted to be able to read the numbersdo you know the numbers that were on your old seals. thanks Randy
