Help on gas start diesel Please
Kevin Cooke
01-02-2006 16:09:40
I need to talk to someone who knows their stuff about 600 650's. My 600 sounds unsmoothand has a small amount of smoke. I rebuilt the injectors($), checked the compression the best I could checked for leaking start valves. Every move made a small improvement but its still not right. When I had the injectors out I noticed that the precups werent installed in the same way in each hole. This is a WD9 head so it has the older injector that comes out easily but how do I get the body and the precups out and willo it make any difference. Also I can determine which cyl is causing the smoke by cracking the bleeder. Any help is appreciated. thanks
Farmaller
01-03-2006 11:09:33
 Re: Help on gas start diesel Please in reply to Kevin Cooke, 01-02-2006 16:09:40
Have you tried to change the timing? This would cause smoke and running rough.
Janicholson
01-03-2006 09:37:56
A pyrometer that measures into a thousand degrees placed on the exhaust manifold will point to a misfiring diesel cyl.
The manual should show how to remove the injectors, and how they (and the precups) are aligned. I believe it does make a difference.
My experience is with older MDs and I don't know about the bleeders.
JimN
