656 Power Steering
rk
01-02-2006 18:26:53
Brother has a 656 that's been setting in the barn for four years, needing head gasket primarily, but has several other issues. Got it cranked today, but power steering doesn't work at all. Hyd fluid is low, but he says this was problem before it was parked. Can anyone give suggestions to trouble shoot, please?
Allan in NE
01-03-2006 02:05:30
 Re: 656 Power Steering in reply to rk, 01-02-2006 18:26:53
RK,
Do the remotes work? If not, you probably need a front pump. They have a habit of wobbling themselves out over time.
Allan
Yellott Canby
01-02-2006 19:09:14
Hello, You might want to check and probably replace the hyd filter. Also fill the oil to the proper level. There are two different size of hyd filter for those. Depends on the serial #.
Good Luck YC
rk
01-02-2006 19:30:37
 Re: 656 Power Steering in reply to Yellott Canby, 01-02-2006 19:09:14
Thanks YC, we plan to do that and hope it works, but not greatly optimistic as the filter looked good and he says problem was there before with good oil level. But we'll try it, maybe we'll get lucky?!
