question on MW hand clutch
Nebraska Kirk
01-02-2006 18:52:06
I got the hand clutch installed on my M and now I have a question. Where do I hook the brake return spring???
DWV
01-03-2006 05:27:05
 Re: question on MW hand clutch in reply to Nebraska Kirk, 01-02-2006 18:52:06
A hole was drilled in the brake pedal (inside pedal on right side of tractor) and a special anchor pin was installed for that end of spring.
For other end of spring a short metal strap with 2 holes bolted to brake cover bolt.These parts can be made pretty easy if missing.Also the originial spring mounting arm is suposed to be cut off for clutch housing clearance.
