F14 steering wheel
George Andrease
01-03-2006 06:13:15
I'm considering buying an F14 that's quite some distance away. I've only seen photos so far and the tractor looks complete, but has some sort of car steering wheel on it. I want to put one of the 4 spoke iron steering wheels on it. There are two listed on Ebay right now...one with an 11/16" center hole and one with a 7/8" hole. One of them came of an F20, but I'm not sure which will fit. Can anyone tell me? Thanks! George
Sloroll
01-03-2006 07:07:51
 Re: F14 steering wheel in reply to George Andreasen, 01-03-2006 06:13:15
An F-14 has a automobile style plastic wrap steering wheel not a cast one. Do you have a photo so someone here could see if the one you are looking at is correct? An F-20 steering wheel is not the correct size.
Aberdale Farm
01-03-2006 15:30:40
 Re: F14 steering wheel in reply to Sloroll, 01-03-2006 07:07:51
I'm certainly no expert, but I own two F12s. One is a 1934 model, the other is a 1938 model. The 1934 has a cast four spoke steering wheel, while the 1938 has a fully covered hard rubber steering wheel. I don't know what year they were changed from cast to rubber.
Dale
George Andreasen
01-03-2006 07:20:56
Thanks....I thought I had seen photos of the F12 and F14 with the iron wheel and assumed that was normal and IHC would have made them interchangeable. If they came with the rubber covered spoked wheel, I'll look for that instead. George
