early model hydro utility
CIH 9280
01-05-2006 08:25:15
Looking for a hydro utility with 3pt.
and live pto. like a 656 but smaller.
not sure how many models were made back
in those days.
Thanks for your help!!!!! !!
Bruce Wa.
01-05-2006 18:09:30
 Re: early model hydro utility in reply to CIH 9280, 01-05-2006 08:25:15
I've got a 544 hydro. Good tractor but the 656 is more common. Mine is a gas. The diesel would be much better than the C200. Actually they are basically the same tractor with a 4 or 6 cylinder engine. The 656 uses a 263 gas or 282 diesel. Both very common engines. Gas is very hard on fuel.
Aces
01-05-2006 10:14:27
Tractor Vet you are right the 544 U was first Hydro IH made. I remember a recall on one of the very first and I changed the hydro in it.
the tractor vet
01-05-2006 08:44:25
I think that they made a 544 in a hydro but i am not into hydros to many problems and way to costly to fix . myself i stick with a gear drive atleast you can fit them with out to much trouble and a clutch is a whole bunch cheeper then a pump or hdy motor .
