H F12 wheel hubs
mmpriar
01-06-2006 09:27:48
Can any of you guys tell me if the axels on an H or M are the same as an F12. I was wondering if I could use H or M Wheels/rims/hubs on my F12.
Thanks
John M
01-06-2006 14:06:29
 Re: H F12 wheel hubs in reply to mmpriar, 01-06-2006 09:27:48
H hubs WILL fit!
mcraig
01-06-2006 12:11:54
I didn't know the diameters of the axels. I just know a few years back I tried to put f-12 wheels on my H and the keys are different widths. Hope that helps.
Dr.EVIL
01-06-2006 11:00:16
H axle is 2-1/2" dia.; M is 2-3/4" dia. ; F-12/14 is 2-5/8" dia. I suppose with enough grinding or welding anything is possible. ;-)
mcraig
01-06-2006 10:45:40
I think h and m wheels can be used on f-12's easier than f-12 wheels can be used on h's and m's.
Nebraska Cowman
01-06-2006 09:37:31
I believe there is 1/8 difference in size. They can be made to work.
moseed
01-06-2006 15:27:33
 Re: H F12 wheel hubs in reply to Nebraska Cowman, 01-06-2006 09:37:31
The F-12 is larger and H wheels will fit however with use the hubs can crack I've been told. I've measured and seen the difference however the cracked hub story was related to me.
Good Luck.
