Super C belt pulley questions
Chris in Washin
01-06-2006 16:36:22
Is there a belt pulley and gear box that is specific to the SC or does the one that fits the SC also fit several other models? Does anyone have part numbers for them? Also, how is the gear box driven? Is there a shaft attached to the gear box, or is there a separate shaft that goes into the tractor and fits into the gearbox, or is there a shaft immediately under the tractor's block off plate that the gearbox fits over?
AC Hodges
01-06-2006 20:56:21
 Re: Super C belt pulley questions in reply to Chris in Washington, 01-06-2006 16:36:22
The belt pulley drive for the SC is the same as the C,A,SA,and B. When you remove the block off plate there is a shaft there but you will need a gear if the PTO didn't come with the belt Pulley. The belt pulley drive bolts in place of the block off plate with shims to adjust the gear backlash.
Binderboy
01-06-2006 17:50:44
Super C belt pulley is driven off right side of pto housing on back of tractor. Should be splined shaft sticking out of housing.
Chris in Washington
01-07-2006 11:37:27
 Re: Super C belt pulley questions in reply to Binderboy, 01-06-2006 17:50:44
Thanks, I looked through my manuals and couldn't find any info.
