340 Farmall back in action
Wayne L
01-06-2006 18:03:14
Hey! Hey! Hey!
Everyone. Thank you very much for all your help. It's purring again. Sound of music. Turns out that the distributor that I put on this fall was carbon arching and grounding out. Once I replaced that it fired up almost instantly. Thanks again for everyones help. I now can try to figure out why my rebuilt hyrdralic pump is cavitating when I first start up and when it runs at higher rpm. I did try to bleed the air off to no avail.
Wayne
El Toro
01-07-2006 07:37:46
 Re: 340 Farmall back in action in reply to Wayne L, 01-06-2006 18:03:14
I would agree with William. Hal
williamf
01-07-2006 04:53:37
Success is a good thing, eh?
When I hear of a cavitating hydraulic pump the first things that come to mind are a restriction on the supply to the pump or a leak on the supply side letting air in. Can either be a possibility with that model?
Wm
