Novice farmer?
tchr66
01-06-2006 20:10:49
We hadn't planned on it but, my mom and I are now the owners of a nice old Farmall. I am trying to figure out some information about this old machine. One problem, I do not know what model it is. Can someone help me out in this area? (The only identifier that I have found on it so far is the Farmall plate on its front end.
Hugh MacKay
01-07-2006 04:50:22
 Re: Novice farmer? in reply to tchr66, 01-06-2006 20:10:49
tchr66: To add to what SGT has told you, if it has the word Farmall across the top of the grill you are looking for a letter series Farmall. The Super letter series will have an IH emblem in center at top of grill. If that be the case you are down to 5, maybe 6 models, being the A, B, C, H and M. I'm not sure if the Cub ever had Farmall across top of grill.
To narrow it down further for you, Cub and A were offset with operator platform on right and engine to left. B was similar but all were narrow front from the factory. C had the steering shaft go down the left side of torque tube and on to front along side engine via two U joints. H and M have the steering shaft go along the top of fuel tank, going under hood just ahead of fuel tank. These features will help shorten your search. From here follow SGT's instructions. And let us know what you discover, this is half the chalange for old guys like me.
SGT K
01-06-2006 20:21:25
Look over on the left side of the page in the GALLERIES section. Open up the TRACTOR PHOTOS and I bet you wil see a Farmall photo that you recognize.
Also look for the serial number tag. It will probably be on the left side of the bell housing (under the gas tank right behind the engine) or below the seat. If you find those numbers the guys can tell you what it is and what year it was built.
Good Luck
Paul
tchr66
01-08-2006 16:26:52
 Re: Novice farmer? in reply to SGT K, 01-06-2006 20:21:25
Thanks for all your help. Turns out this is an H sitting in my yard. Now all we need to do is getting it to run on a more reliable basis.
Thanks again for the assistance.
CNKS
01-07-2006 13:53:32
In addition the serial prefixes for different models are -- FAA, A;, FAB, B;, FC, C; FBH, H; FBK, M.
